I have a ZigBee plug connected to a circulation pump on my water heater. I'd like to create a button that will run the circulation pump for 5 minutes then shut off.
Can someone please point me in the right direction?
Thanks!!
Thanks!!
By create a button do you mean you want to create a virtual button?
If you want a virtual button just go to devices > add device > Virtual > setup a virtual button.
The basic rule app could do that. It will step you through the process.
You could also do it with a fairly simple Rule machine rule.
Trigger: Button pushed.
action:
turn on switch
delay 5 minutes
turn off switch
