That thing looks cool, but man what a bad time to be the maker of a device that seems much less valuable if people aren’t in the same physical workspace together...
if the kuando busy light was wireless and battery powered it would be perfect
just found this Buy now: the legendary Luxafor Bluetooth busylight! - Luxafor
I have used this exact device as well. It also can be controlled via an api for automation etc. More technical but lots of code examples can be found on GitHub. One caveat, sucker eats through the charge fast, I ended up soldering in a power supply
I use Presencelight from Microsoft store, which connects to Microsoft Teams. You can use the custom API calls to work with thing in Hubitat.
