Odd Hue Issues
Hi - Been having a strange Hue issue for months now. When I hit my Pico switch to trigger my kitchen cabinet hue lights, it will put them to the incorrect color and brightness settings. It seems to go back to the last setting they were on vs the setting mapped to the Pico button I just pressed. I captured a log of it a few months ago, it's still doing it on an almost daily basis. Anyone else seeing behavior similar to this?
Are these directly-paired Hue lights (i.e., Zigbee directly to Hubitat), or are they Hue Bridge lights (e.g., using the built-in Hue Bridge integration or a community alternative)? If they are directly paired to Hubitat, there have been lots of reports of Zigbee bulb problems over the years when certain commands are issued in quick succession (something like "on" or "set level" followed by "set color temperature" or something, but I don't remember the exact problematic commands or their order). I believe staff have stated they have some ideas for how to fix this that should be in the next hub firmware release, 2.2.5, but no timeline on that yet. A workaround some have found in the meantime is to put a small delay between the commands or issue the "second" one twice after a small delay. For a Pico, that could be as easy as just pressing the button again a second or so later if things aren't quite right after the first time.
If they are Hue Bridge bulbs, that would be a different problem. The Bridge is pretty reliable in my experience, so maybe something else is going on. Do you think it could be your app/rule? Feel free to share a screenshot of that configuration if so.
Are the lights being powered off by the switch? When I mean powered off is the power being cut from the lights. Or is the switch always on and just sending the command via z-wave and the hue bridge?
If the lights are being powered off completely then inside the hue app you need to adjust the power on behavior. Here you can set the lights to come on at a brightness and color that you wish.
The pico switch would be sending the commands together when turning on which wouldn't work.
Sorry for the delay in my reply. I am using the Hue bridge so it should be pretty reliable and I'm not cutting power to the Hue lights. Here is a log from when it happens, it's like it tries to set it correctly and then something is coming over the top of it to put it back. Thank you for helping out!
dev:152020-09-29 09:22:33.242 am infoHue lightstrip under cab stove color temperature was set to 2762°K
dev:142020-09-29 09:22:33.212 am infoHue lightstrip Under Cab Sink color temperature was set to 2762°K
dev:362020-09-29 09:22:02.751 am infoOffice Motion Sensor: battery is 100%
dev:142020-09-29 09:21:53.229 am infoHue lightstrip Under Cab Sink saturation was set to 55%
dev:142020-09-29 09:21:53.227 am infoHue lightstrip Under Cab Sink hue was set to 13%
dev:142020-09-29 09:21:53.225 am infoHue lightstrip Under Cab Sink level was set to 99%
dev:152020-09-29 09:21:53.189 am infoHue lightstrip under cab stove saturation was set to 55%
dev:152020-09-29 09:21:53.187 am infoHue lightstrip under cab stove hue was set to 13%
dev:152020-09-29 09:21:53.185 am infoHue lightstrip under cab stove level was set to 99%
dev:472020-09-29 09:21:53.145 am infoKitchen Can Lights was set to 100%
dev:482020-09-29 09:21:53.081 am inforcvd: OUTPUT,12,1,100.00
dev:452020-09-29 09:21:53.065 am infoTable Chandelier was set to 75%
dev:482020-09-29 09:21:53.006 am inforcvd: OUTPUT,4,1,74.90
dev:462020-09-29 09:21:52.988 am infoSink Pendants was set to 100%
dev:482020-09-29 09:21:52.930 am inforcvd: OUTPUT,5,1,100.00
dev:432020-09-29 09:21:52.910 am infoKitchen Scene Pico 1 button 1 was released
dev:482020-09-29 09:21:52.858 am inforcvd: DEVICE,13,8,4
dev:232020-09-29 09:21:52.788 am infoKitchen Daytime was turned on
dev:432020-09-29 09:21:52.709 am infoKitchen Scene Pico 1 button 1 was pushed
dev:482020-09-29 09:21:52.657 am inforcvd: DEVICE,13,8,3
dev:62020-09-29 09:20:33.600 am infoGroup Hue Under Cabinet color temperature was set to 2762°K
dev:52020-09-29 09:20:33.582 am infoGroup Hue Over Cabinet color temperature was set to 2882°K
dev:132020-09-29 09:20:33.462 am infoHue lightstrip under cab fridge color temperature was set to 2762°K
dev:112020-09-29 09:20:33.435 am infoHue lightstrip over cab stove color temperature was set to 2882°K
dev:152020-09-29 09:20:33.405 am infoHue lightstrip under cab stove saturation was set to 99%
dev:152020-09-29 09:20:33.403 am infoHue lightstrip under cab stove hue was set to 10%
dev:152020-09-29 09:20:33.401 am infoHue lightstrip under cab stove level was set to 16%
dev:122020-09-29 09:20:33.363 am infoHue lightstrip Top Cabinet Sink color temperature was set to 2882°K
dev:142020-09-29 09:20:33.325 am infoHue lightstrip Under Cab Sink saturation was set to 99%
dev:142020-09-29 09:20:33.323 am infoHue lightstrip Under Cab Sink hue was set to 10%
dev:142020-09-29 09:20:33.321 am infoHue lightstrip Under Cab Sink level was set to 16%
dev:132020-09-29 09:20:03.200 am infoHue lightstrip under cab fridge saturation was set to 55%
dev:132020-09-29 09:20:03.194 am infoHue lightstrip under cab fridge hue was set to 13%
dev:132020-09-29 09:20:03.190 am infoHue lightstrip under cab fridge level was set to 99%
dev:132020-09-29 09:20:03.183 am infoHue lightstrip under cab fridge was turned on
dev:142020-09-29 09:20:03.122 am infoHue lightstrip Under Cab Sink saturation was set to 55%
dev:142020-09-29 09:20:03.119 am infoHue lightstrip Under Cab Sink hue was set to 13%
dev:142020-09-29 09:20:03.117 am infoHue lightstrip Under Cab Sink level was set to 99%
dev:142020-09-29 09:20:03.114 am infoHue lightstrip Under Cab Sink was turned on
dev:152020-09-29 09:20:03.064 am infoHue lightstrip under cab stove saturation was set to 55%
dev:152020-09-29 09:20:03.054 am infoHue lightstrip under cab stove hue was set to 13%
dev:152020-09-29 09:20:03.033 am infoHue lightstrip under cab stove level was set to 99%
dev:152020-09-29 09:20:03.014 am infoHue lightstrip under cab stove was turned on
dev:62020-09-29 09:20:02.963 am infoGroup Hue Under Cabinet saturation was set to 55%
dev:62020-09-29 09:20:02.961 am infoGroup Hue Under Cabinet hue was set to 13%
dev:62020-09-29 09:20:02.959 am infoGroup Hue Under Cabinet level was set to 99%
dev:62020-09-29 09:20:02.932 am infoGroup Hue Under Cabinet was turned on
dev:122020-09-29 09:20:02.552 am infoHue lightstrip Top Cabinet Sink saturation was set to 48%
dev:122020-09-29 09:20:02.549 am infoHue lightstrip Top Cabinet Sink hue was set to 13%
dev:122020-09-29 09:20:02.547 am infoHue lightstrip Top Cabinet Sink level was set to 84%
dev:122020-09-29 09:20:02.543 am infoHue lightstrip Top Cabinet Sink was turned on
dev:112020-09-29 09:20:02.502 am infoHue lightstrip over cab stove saturation was set to 48%
dev:112020-09-29 09:20:02.500 am infoHue lightstrip over cab stove hue was set to 13%
dev:112020-09-29 09:20:02.498 am infoHue lightstrip over cab stove level was set to 84%
dev:112020-09-29 09:20:02.495 am infoHue lightstrip over cab stove was turned on
dev:52020-09-29 09:20:02.451 am infoGroup Hue Over Cabinet saturation was set to 48%
dev:52020-09-29 09:20:02.449 am infoGroup Hue Over Cabinet hue was set to 13%
dev:52020-09-29 09:20:02.447 am infoGroup Hue Over Cabinet level was set to 84%
dev:52020-09-29 09:20:02.445 am infoGroup Hue Over Cabinet was turned on
dev:472020-09-29 09:20:02.248 am infoKitchen Can Lights was set to 100%
dev:482020-09-29 09:20:02.098 am inforcvd: OUTPUT,12,1,100.00
dev:452020-09-29 09:20:02.027 am infoTable Chandelier was set to 75%
dev:482020-09-29 09:20:01.921 am inforcvd: OUTPUT,4,1,74.90
dev:462020-09-29 09:20:01.904 am infoSink Pendants was set to 100%
dev:232020-09-29 09:20:01.884 am infoKitchen Daytime was turned on
dev:482020-09-29 09:20:01.827 am inforcvd: OUTPUT,5,1,100.00
dev:432020-09-29 09:20:01.812 am infoKitchen Scene Pico 1 button 1 was released
dev:482020-09-29 09:20:01.759 am inforcvd: DEVICE,13,8,4
dev:432020-09-29 09:20:01.677 am infoKitchen Scene Pico 1 button 1 was pushed
dev:482020-09-29 09:20:01.575 am inforcvd: DEVICE,13,8,3
