Octoprint integration?
Just curious if anyone has integrated OctoPrint with HE.
It would be nice to get status, notifications, turn things on/off, etc.
Seems like it would be possible for an HE app to use octoprint’s REST api for job status, etc.
You could also curl into the HE maker API using custom commands on octoprint. I’m thinking about doing this to shut off the printer (Zigbee outlet) when the print is done
Have you made any progress on this? I use Cura and Octoprint. I would like to turn on my printer when I send the gcode to octoprint from Cura.
I have not had a chance to try... Haven't even fully gotten octoprint running.
I know that this is an old thread but just wanted to put it out there that Octoprint has MQTT plugins for monitoring as well as controlling your printer. So you should be able to monitor print status etc from the dashboard through kevins MQTT app or node-red/Maker API.
Lots of threads on this.
Saw that, thanks! The octoprint server can put out so much more data that is easily accessible via MQTT although I guess it shouldn't be too hard to expose these via the HE driver?
