Hi Guy's, Im wondering what is going on, Nyckelharpa + Iris v3 Keypad (Centralitex Keypad driver) is not respecting my 60 second exit delay configured in the Keypad driver.
When "On" is pressed, my Hub arms to away mode almost instantly.
I have the same setup with a couple of UEI keypads thrown in the mix. I can't remember the last time I armed away with the Iris but I'll try and remember to try mine when I get back to the house this week. I usually arm with the UEI that's outside next to the entry door but I do hear the iris doing the 30 seconds of beeps when arming.
I'll tag Arn @arnb maybe he has an idea. I know it's been a very, very long time since he has looked at this code. I don't think I've even opened the nyckelharpa app in several years myself. Everything just works.
I don't know. Based on that screenshot you should be seeing a 40 second delay on exit. Did you try hitting next and done on the global settings? Maybe something is garbaged up.
Not sure if it would hurt anything but you could change the keypad driver to a device. Clean everything out then switch back to centralitex, hit configure and set it back up.
The instructions for setting up nyckelharpa were quite good. You could pull those up and make sure that you followed each step. If I remember correctly, if you don't follow the setup instructions you can get unexpected results.
Wish I could give you a more definitive answer. I do remember years ago having to nuke the nyckelharpa setup and start from scratch a couple times after I managed to mess it up.
Thanks mate. I only discovered the issue when our house sitter kept having issues - we are away on vacation atm and troubleshooting it remotely is a royal pain.
