NX1000 / Evolve1 - Configuration
recently moved from Vera to Hubitat, and have hit a wall in getting my Nx1000 / Evolve1 set up correctly.
Ive installed the driver in github by @wayne.pirtle
I've successfully updated button text, but after spending a full day trying to get actions to trigger consistently without success, wanted to reach out to the community for assistance.
A few questions:
  1. in @wayne.pirtle code, is there a mechanism to select which devices are impacted by each button push?
  2. Assuming the answer to #1 is 'no', what are the best practices for mapping button pushes to actions.
  3. Can button presses be mapped to Scenes? (can i create a scene in the Groups/Scenes App, and then call that scene via a button push from the NX1000?)
thanks for any help you can provide...and if there's a better place to post, please just let me know...
thanks!
Brian
Hi, @brian.kane! Welcome to Hubitat.
The driver I created exposes the NX1000 as a 15-button controller. To effect an action, I suggest using the Basic Button Controller app that the Hubitat team built. It will let you actuate devices and scenes on the press of a button on your NX1000.
Since I created that driver, the Hubitat has a delivered driver for the NX1000/Evolve1. It also recognizes the NX1000 as a 15-button controller. I would also give that a try, because it will be updated if necessary. I use it and it works well.
thanks, im grateful for your reply....with that info you provided, im probably going to start from scratch using the driver that Hubitat delivered and will take it from there... thanks for the quick reply
