Null - Notifications
Hello there, tried searching for an answer and couldn’t find one so here goes. Every so often around 2-3 hours I get a notification with just the word Null in it? Maybe has something to do in the logs of Nullsystemstart? Any help or advice? @bobbyD
Is this in logs or an actual notification? What do logs shows at that time? You can click on the app number in the logs to see what is causing it (if its in logs).
Should also be able to go the event list on the notifications "device" linked to your mobile app. This will show you what is sending the notifications.
Example:
Thanks it’s an actual notification. Will look in the device now to see if I can find out why it’s sending it.
Edit: I think I found it. Many thanks.
