Hello - I'm brand new to Hubitat and really liking it so far!
One thing I've been having trouble configuring is a notification based on temperature change. I'd like to receive a notification when the temperature of a sensor changes plus or minus 20 degrees within 30 minutes.
The use case is:
I have a temperature sensor under my gas fireplace. It doesn't get hot enough to damage the sensor but it does get hot enough to tell me if the fireplace is on or off. All the rules I've experimented with (temperature => 90 degrees) notify each time the temperature on the sensor updates so I get too many notifications. I think a better way would be to compare the amount of temperature change over time and alert if the temperature rapidly goes up (fireplace on) or temperature rapidly goes down (fireplace off).
Thanks for your advice.
