I created a notification setup to send my device a message when my temp sensors drop below 50 degrees. However, I'm receiving a temp notification regardless of the temp, even outside of the parameters set. Any insights into anything wrong on my end? Screenshots enclosed.
Sounds like a bug… Tagging @bravenel
Those two conditions are independently tested. You're notified every time the temperature is greater than or equal to zero.
Remove the 0 from the >= condition. Just tested this, works as expected. Hit Done after removing the 0.
Will make it clearer in the next release, like this;
