Notification Not Repeating
I just tried that on a spare, older, ZEN16.
Works as it should.
ZEN16 only takes dry contact, no voltage. So, what are you energizing?
Is it a new ZEN16? Inputs can be separated from relay, etc.
The output on the alarm system is 12vdc, which energizes the interposing relay, the interposing relay has a dry contact, the dry contact interfaces into the ZooZ, (switch), I use the ZooZ as the input, in normal (no alarm) it [OFF] [0], in alarm state its [ON] [1]
Is it a new 800LR ZEN16?
correct, ZEN16 800LR
I wonder if there's something in here that could be a factor?
Like, what's your parameter 2 for the input switch you're using?
Or this?
I also used a fluke meter, the input is not toggling, the switch mimics the interposing replay output, when in alarm, its [ON], when normal its [OFF], and the switch "state" does not toggle, I even put a direct jumpers wire on the ZooZ input to mimic a switch, same results, one message then stops
Maybe get a report of all the parameters and then check it out.
thanks for all your support. I need to take a break on this to work on another project, I will get back to this later in the day
Yeah, me too, lol.
This is the what I do for my company, electrical engineering and control systems
This is one panel of several panels on one project
Though it doesn't solve whatever root issue is afoot here, another option to consider is using Pushover's Emergency priority.
That's how I handle notifications that I need to get my attention no matter what.
Pushover: Emergency priority explanation
Hubitat setup:
https://docs2.hubitat.com/en/devices/pushover#priority
I might be onto something, or not, lol:
Something about cycling the triggering device (ZEN16) on and off to clear states...or something like that.....
Reading closer, it's about a restriction switch, but stil....
perhaps @bravenel could weigh in at some point....
What does "Cycled the triggering device" mean? How is that done?
Does he mean cycle the input device in my case the ZooZ realy from [OFF] to [ON] then [ON] to [OFF]?
If so, I did that 20-30 times are ready
Is it getting to your phone at least once?
yep, every time, but just once
how can I reset the C8 back to "out the box" and start over? back Factory default
