Not sure what this error means
Rule seems to be working but it's throwing this error.
Maybe the 2 second repeat is too fast? Slow it down a bit and see if you get the same error.
I still get it at 4 seconds. I ran the rule again while watching the logs live and the air doesn't pop up until I close the door.
Maybe post the log, are you getting multiple triggers? Does the contact bounce on and off when closed?
This is odd. It looks to me like I'm getting a double running of the end of the rule.
At .254 it appears to have triggered a second instance while the original was still going.
This is your rule trigger when it's closed because your trigger is changed. I would try to change your trigger to opened. Within the context of triggering your rule, I think contact closed only cancels the delay and I don't see any harm without canceling it. The previously triggered rule will still run to completion and I think this may eliminate your error. Just a guess though.
Interesting idea. I'll give that a try.
Little back story, this used to make use of a different siren that had a tone that repeated non stop. When I replaced that device I had to modify the rule to have the same effect to repeat as long as the door is open.
I still have that siren in the network so may be I'll test out what happens when I go back to it.
Edit: I can use the new sticky trigger!
I'll give this a try in the morning...
That worked to use sticky trigger!
