After a power loss my sharptools account can't see my HE hubs, and also all my hubs are unable to successfully check for updates now. These hubs all had 2.3.5.105 on them
Go to Settings > Network > Network test. Try to ping a domain like google.com or run the speed test. This will tell you if DNS is working.
If it fails, I would do a network reset: Network Setup | Hubitat Documentation
This will reset any network settings that may be causing an issue and revert it to DHCP, then reboot.
You can also manually set DNS servers in the network settings, which is covered in that same doc.
Thanks, it was a router issue. Needed a reboot I guess. It was strange as everything else on the network was fine.
