Non battery powered Zigbee devices stopped working
I have C8 hub with 2.3.9.193 version.
I did the update to .193, 4 days ago and everything was working fine until suddenly last night all non-battery Zigbee devices stopped working.
I tried to remove one repeater and it didn't connect back anymore so I stopped removing devices for now.
I also have tried these things:
  • restarting the hub
  • disabling Zigbee, shut down, power off and wait for couple minutes, then back on and enable Zigbee
  • rebuild network
  • reboot radio
  • restoring from last backup
  • restoring from backup of previous version
Nothing works and I still have the same problem.
My motion sensors and temp sensors are working fine as they are battery powered, but that's it, nothing else works in Zigbee.
After making these two changes everything is back to normal:
  • Since 2.3.9.192 supports Sonof Motion (SNZB-06P) using Sunricher MW Motion Sensor driver I have one of those and I did switch the device type to the new one after the update, but I just reverted that back to the community driver of Tuya mmWave sensor
  • I did shut down the hub for maybe 10th time and I also swapped the hub antenna's.
Not sure which one of these fixed my issue, but everything is working fine now.
