For those who have Hubitat linked to Node-Red, if I add a new Hubitat device do I need to do anything or will Node-Red see the new device? If not, what steps do I need to follow in order to get the new device visible to use in Node-Red?
You must first select it int the Node-red Maker app you created. Then, yes, the new device will just appear when you edit a device node.
Ahhh ok, that did the trick. Thanks!
