I'm having trouble setting up an AND gate. I am not sure what the input message topic needs to have in it.
As always. Thanks
As always. Thanks
the topic is the name of the device. then you want to make sure you use msg.payload.value for your payload.
Still not working.
I must not understand the topic in the header.
this is the definition in the help:
topic(mandatory) string
the topic of the message. This is mandatory because of the node configuration
string | number | object | bool
the property to test
Which node are you using? Bool gate?
Here you go - here's an example of configuring the Bool gate node for a Boolean AND test ....
[{"id":"13f88029.b09e2","type":"hubitat device","z":"3943b86.98c64c8","deviceLabel":"Right Door","name":"Right Door","server":"a22e0ea9.276dc8","deviceId":"1921","attribute":"contact","sendEvent":true,"x":370,"y":1480,"wires":[["dbf53c6a.f04a88"]]},{"id":"dbf53c6a.f04a88","type":"rbe","z":"3943b86.98c64c8","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload.value","x":530,"y":1440,"wires":[["5d46bba5.93707c"]]},{"id":"5416e560.e29be4","type":"hubitat device","z":"3943b86.98c64c8","deviceLabel":"Left Door","name":"","server":"a22e0ea9.276dc8","deviceId":"1920","attribute":"contact","sendEvent":true,"x":380,"y":1400,"wires":[["dbf53c6a.f04a88"]]},{"id":"5d46bba5.93707c","type":"and-gate","z":"3943b86.98c64c8","name":"","rules":[{"t":"eq","v":"open","vt":"str","propertyType":"msg","property":"payload.value","topic":"Left Door"},{"t":"eq","v":"closed","vt":"str","propertyType":"msg","property":"payload.value","topic":"Right Door"}],"outputTopic":"Status","gateType":"and","emitOnlyIfTrue":false,"x":680,"y":1440,"wires":[[]]},{"id":"a22e0ea9.276dc8","type":"hubitat config","name":"HubitatM","usetls":false,"host":"192.168.1.46","port":"80","appId":"1522","nodeRedServer":"http://192.168.1.4:1880","webhookPath":"/hubitat/webhook","autoRefresh":true,"useWebsocket":false}]
Hope this helps!
Thanks. I appreciate the help
I just found, I think one of my headaches from last night.
