I release a version to fix 401 issue when NR login is enabled
Even if it seems not related, can you try it @erktrek
During this time, I'll try a setup with nodejs 14
edit: no issue with nodejs 14.16.1 with npm 6.14.12 and NR 1.3.3
I've not been having any issues with HE nodes, and I've been doing a lot of tinkering these last few days. No login to Node Red.
@erktrek If you still have issue after 1.7.1
Go to this url: http://<host>:1880/hubitat/js/common.js
You should have an explicit error message for the reason why you get 404
Also, can you give me the output of this command
ls -l /<NR install>/node_modules/node-red-contrib-hubitat/nodes/static/*
To be sure that file permissions are ok (you should have only common.js
file)
No issues here on 1.7.0:
Node-red 1.3.3
node 12.22.1
no node-red login
Not that it matters, but node v15 isn't qualified/tested on node-red. Just an FYI - if it works, it works.
https://nodered.org/docs/faq/node-versions
( and now you all know why I'm running old node v12. )
In my settings.js file I have this:
httpAdminRoot: '/admin',
When I access my Node-RED UI I go to:
http://<host>:1880/admin
So this
yields this:
Cannot GET /hubitat/js/common.js
BUT if I do THIS:
http://<host>:1880/admin/hubitat/js/common.js
Then I get info back..
/* eslint-disable no-unused-vars */
/* eslint-disable no-param-reassign */
function cleanHubitatSelectMenu(menuId, defaultText) {
const selectMenu = $(`#${menuId}`);
selectMenu.find('option').remove().end();
const option = $('<option>', { value: '', text: defaultText });
selectMenu.append(option);
selectMenu.val('').trigger('change');
function resetHubitatSelectMenu(menuId, defaultText) {
const defaultOption = $('<option>', { value: '', text: defaultText });
selectMenu.append(defaultOption);
return selectMenu;
function paramsFromServer(server) {
return {
usetls: server.usetls,
host: server.host,
port: server.port,
appId: server.appId,
token: server.credentials.token,
function cleanHubitatDevices() {
cleanHubitatSelectMenu('node-input-deviceId', 'Choose device...');
function listHubitatDevices(server, deviceId) {
const selectMenu = resetHubitatSelectMenu('node-input-deviceId', 'Choose device...');
$.getJSON('hubitat/devices', paramsFromServer(server), (res) => {
res.forEach((item) => {
const selected = deviceId === item.id;
const option = $('<option>', { value: item.id, text: item.label });
if (selected) { selectMenu.val(item.id).trigger('change'); }
if (!deviceId) { selectMenu.val('').trigger('change'); }
}).fail(() => cleanHubitatDevices());
function loadCredentials(server) {
return new Promise((resolve, reject) => {
if (server.credentials) {
resolve();
} else {
$.getJSON(`credentials/hubitat-config/${server.id}`, (data) => {
server.credentials = data;
server.credentials._ = $.extend(true, {}, data);
resolve();
}).fail(() => reject());
Nice !!
It's not simple/quick to fix (to handle this parameter), so I'll make some tests and will try to release something tomorrow
Its all good - the earlier version still works great for me so I'm okay for a bit. If you need me to do any further testing etc let me know!
Well I was wrong, it's was really simple/quick to fix
1.7.2 released with the fix, enjoy
webpage login works great.
Thanks for a great JOB.
Works great thank you!!!!
