Getting this error after one test alert ( which took about 15 min to go from activation to hearing the test alert. Also in the logs the warning says device caused hub overload - the device in the log is the google mini used to broadcast the alert. The google mini is not used for anything else.
Assume the issue is with the following community app? If so you should post within that thread to get better support and attention from the developer. Or maybe one of the @moderators can move this post there for you.
