is there no way to do this other than first setting it in a variable and then setting.. seems like a new option is needed.
use case
have two attributes changing in one device and via a "changed" trigger want to set a corresponding attribute in a different device based on the %value% in the trigger , seems counter inuitivfe that i first have to push it to a variable and then run a custom action..
seems like a new action set attribute name %value% would be very usefull thanks
