this for the older aeon home energy clamps .. may work on newer versions as well.
i previously posted this driver it is on package manager.
i got a new dryer and have been pulling my hair out as this one has one or two cooldown (still spinning) cycles that screwed up my "dryer is done" rule.
I added parameters to set minimum watts before the "switch" toggles to say the load is done.
I had previously added, a max to ignore faulty readings starting if over a cerrtain wattage, and also a flag to ignore tracking (if you are only using it for either a washer or dryer like me)
adding that parameter and configuring greatly simplified my rule
