thanks @thebearmay. So its harmless and it's how it is supposed to be.
I spent few hours doing migration and few questions came up if you guys can give me suggestions..
I have two identical Fibaro Motion sensors. I paired them and updated status by pressing button in motion sensor. How come they report different information.
THIS ONE IS SOLVED. There's pending changes and they are slowly updating.. -
I have Fibaro Smoke Detectors. Found this link and installed groovy.
[RELEASE] Fibaro Smoke Sensor
When button is pressed sensors log file say this:
2021-01-28 12:17:08.308 warnSmoke Sensor Living Room zwaveEvent(Command) - Unhandled - cmd: VersionReport(zWaveLibraryType:3, zWaveProtocolVersion:4, zWaveProtocolSubVersion:24, applicationVersion:3, applicationSubVersion:3)
Nothing to worry about?
Also what is that fibaro smoke detector json file in github. I did just copy that fibaro smoke detector groove file and I assume that is enough right?
- For some reason my webcore pistons are not working. I did take a backup and import them one by one to hubitat side. Resumed couple of pistons but nothing happens. I did not have time to see what's going on but probably this will be solved later when I have more time.
Actually can someone confirm that send push notification on piston works same way in Hubitat as it works in ST. Should I get push notification from my Hubitat App?
EDIT: it's probably this section which need to be configured to receive push notifications from webcore.
Popp water shut off valve was not easy to pair. Finally got it and had to change device to Dome water shut off. It seems to work as Dome but started to think that is that safe to use other driver which is not made for the exact device. I mean..if generic driver would work should I prefer that? I did not find any popp users here.
What purpose does device* line have:
Here's example from one of the devices. It's Hank one key but when paired hubitat said it is Aeotec Nanomote. I changed type to hank one-key and device is working. I gave it a Device label name but what about that Device name. Where is that used and can I changed it without problems. And.. does it even matter what it is because most likely log files uses device label line right?
