New user GH, Sengled bulb, and HE
I'm new to HE and just got a 4 pack of Sengled Tunable White zigbee bulbs (no Sengled hub). I've added them to the devices and can setup my simple automation in HE fine. My issue is that I want the ability to use Google Home to change the white hue, either by voice or by section on the Google/Nest display/hub.
I'm assuming Google/Nest Hub won't show the bulbs because they aren't wifi and I don't have them setup with a Sengled Hub. If that's right, can't I still use voice since I have the Google Home integration loaded?
Also, I've noticed that when I go into HE, the Google Home integration app only lists my ecobee thermostat, even though I've added/toggled ALL available devices and saved it in both HE and GH. Thoughts of why it keeps dropping?
You need to install the google home integration. Though the newer one in the Hubitat Package Manager is more feature rich. (Don't install at the same time). Once you do that the bulbs will be exposed to google.
Did that, still not showing up on the Google Hub or in the Google Home app.
