Morning all. Just picked up my Hubitat last night. Looking to possibly transition over from Home Assistant / Node-Red currently running in a docker container on my home NAS. So far I've been impressed with the z-wave response with Hubitat; however, I'm a little concerned with a couple of devices.
All devices on my network have static IPs.
My single Sengled zigbee bulb works. Hooray!
Any tips with the Lifx bulbs? I've grabbed the github code and installed it. When on the dashboard, the controls work fine, but while on the dashboard, if I shut a Lifx light off, it turns itself back on.
We also use Abode as our alarm system. I'm hoping there's some kind of support out there for it. It looks like it's been discussed on the forums but I can't find any sort of support similar to the Lifx bulbs.
Any movement with MQTT? I'm currently using mosquitto with zanzito as my GPS locator of choice for presence detection. I'd like to avoid Life360 since the goal is to be as cloudless as possible.
Is the slow response on the hub's pages normal? Seems as if I need to refresh the page a couple of times to get pages to load. Hub's been updated to 2.4 I believe.
Thanks!
