for example I have this controller for my AC Infinity fans for my server rack. Any way to make this a smart device? https://www.amazon.com/gp/product/B00NG9TSG4/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
I like the clean look of this device locally. but I'm thinking of being remote and wanting to check the metrics/make it smarter
I have a ST multi purpose sensor included as well in the rack. I guess I could use that and then just power the fans by a smart plug.
Any thoughts is appreciated!
David,
Truly dumb devices are easier to automate than a device with some smarts. For example, take a heater that has a built-in digital thermostat. If you hook it to a smart plug to turn it on and off, when you turn the power back on they usually will not start heating. I have one that you have to use the power switch on the heater face or remote control in order for it to start heating after cycling the power. I could use an IR blaster, but it was just easier to replace the heater with one that when you apply power, it comes on. I have the mechanical thermostat settings all the way up and just control the heat provided by switching it on and off based on the readings from a temperature sensor.
In the case of the server rack, you need to look at what the goal is rather than modifying the device just to be "smart". Does the fan controller do the job it was purchased for? If yes, leave it alone. So what are you wanting the smart portion for? Monitor the temperature in the rack? Use the ST sensor for that with automation to notify you if it gets beyond a certain level. Wanting to shutdown the equipment remotely or completely power on/off? What's the goal?
One thing that I continually think about with my smart home automation: Sometimes making it smarter just makes it more complicated and subject to failure. So I subscribe to the "Two is one, one is none." way of thinking and either have a 2 devices handling the same task for failover (i.e. 2 sirens for security or multiple motion detectors in the same room) or at least have a spare that I can quickly swap out (i.e. spare smartplugs).
Bill
Smart plug or a dry contact relay.
I really appreciate the reply.
You are right, i probably am just over complicating the setup. The fan controller does its job just fine. I have the smartthings sensor in there as well to monitor. You suggestion on alerts was great! i now implemented that as well. I think ill leave it as is now.
Thanks again!
If you just want to check itβs stats remotely (although it sounds like itβs quite capable on its own), then just get a Wyze Cam and point it at the display.
