New Sonos Integration stuck on migration
I installed the new integration and it was unable to migrate my existing devices due to some sort of RINCON error. I didn’t have much integrated so I deleted all my Sonos devices to start fresh with the new integration.
When I go into the new integration I am stuck on a migration screen with this message:
Migration cannot proceed:
  • The legacy Sonos Integration has no local player devices.
I’d like to just nuke the old migration off but can’t see the old app anywhere in my setup.
I’m getting a similar error on the migration:
  • The legacy discovery cache contains duplicate player addresses (ADDRESS)
I don’t have any idea what to do about that because the old parent app is now gone @support_team
For what it’s worth, my old devices are still there from the prior integration - and none of them have the address specified as duplicate.
I had the same but after a few attempts my sonos speakers were discovered. It does work better than the previous integration once you have it set up.
Yup, you should be able to do that, however we've discovered an issue in the apps ui where depreciated apps and integrations are hidden when they shouldn't be.
We'll get this fixed and you should then be able to remove the old instance and start from scratch with the new integrator.
Not exactly the friendliest of messages to be honest, however we've found the root cause of this issue and It should be resolved in the next release.
I managed to get into the old app by finding a link to it through the app logs. Once removed the new integration was able to rediscover my devices.
Can confirm that 2.5.2.128 resolved the issue I reported, the migration ran cleanly, and I really appreciate you guys making use of the "disabled" function for the old app (and the deprecated badge) to give us more control over the final removal rather than forcing it. Nice work!
