New set of Sylvania Lightify bulbs not remembering color when powered off and on
I thought the Chinese company had a 30% stake and took over manufacturing. Did they sell 100% to the Chinese company?
I don't see any reference to Osram anywhere. But I haven't done a deep dive on it.
ABOUT LEDVANCE LLC
LEDVANCE GmbH is a fully-owned subsidiary of OSRAM GmbH and is one of the world's leading providers of lamps for professional users and retail customers. In North America, LEDVANCE LLC offers SYLVANIA advanced LED lamps as well as a wide range of traditional light sources, standardized luminaires and connected lighting solutions. The SYLVANIA brand leadership in the industry is a result of a proud legacy of over 100 years of lighting experience and paves the way for future success. LEDVANCE is active in more than 120 countries and has about 9,000 employees. Additional information can be found at www.sylvania.com.
ABOUT OSRAM
OSRAM, based in Munich, is a globally leading lighting manufacturer with a history dating back about 100 years. The product portfolio includes high-tech applications based on semiconductor technology such as infrared or laser lighting. The products are used in highly diverse applications ranging from virtual reality, autonomous driving or mobile phones to smart and connected lighting solutions in buildings and cities. In automotive lighting, the company is the global market and technology leader. Based on continuing operations (excluding Ledvance), OSRAM had around 24,600 employees worldwide at the end of fiscal 2016 (September 30) and generated revenue of almost โ‚ฌ3.8 billion in that fiscal year. The company is listed on the stock exchanges in Frankfurt and Munich (ISIN: DE000LED4000; WKN: LED400; trading symbol: OSR). Additional information can be found at www.osram.com.
It was sold off to a Chinese conglomerate:
In July 2016, the former general lighting lamps business of OSRAM SYLVANIA was carved out into a separate legal entity, LEDVANCE LLC. In March 2017, LEDVANCE LLC was sold to a consortium of Chinese companies consisting of the investor IDG Capital, the Chinese lighting company MLS Co., Ltd. (MLS) and the financial investor Yiwu State-Owned Assets Operation Center (Yiwu).
Here's the response I got from Sylvania:
The LIGHTIFY name has been re-branded to SMART+. Our new SMART+ line includes both Bluetooth and ZigBee smart lighting products. These products have the added benefit of enhanced technology to help make the products more reliable and adaptable for future enhancements. Please note that the slightly different technology used inside our ZigBee bulbs may mean different compatibility with ZigBee systems. We are working on incorporating all our new SMART+ products with the most popular systems, but always double check to make sure your product is supported.
Unfortunately, they didn't answer if I can firmware update the Lightify to SMART+ features, but it sounds like that's a no. I'll be returning the Lightify's for SMART+s.
I went through this some time ago. What I discovered from Sylvania is that the RGB bulbs will remember their setting through power cycles. BUT, it takes them a while to learn their setting. Leave them on for at least five minutes to the desired setting and they should turn back on with the pre power off setting, both color and intensity. If that doesn't work then they have indeed changed something in the design.
did you ever figure this out my wife is teh same way,, i have the new smart + ones, i jst want it to default back to daylight color, you have any good rules setup i coudl see or how did you get tehm to stick to the on color you wanted?
Just wanted to comment here as I was also looking for a solution to the lights staying a set color on power up.
To do this, you need to remove the lights first from the hub youโ€™re using be it habitat or SmartThings. Then, plug in a Lightify hub you may have never used. Via the Lightify app after setting it up and letting it run firmware updates, pair your lights. They likely will also update their firmware.
Once the lights are set up and updated you then pick the color you want as the power in default.
Then in the upper right corner of the light screen, click the power switch and apply the new default.
Thatโ€™s it. Once you do that - it writes that value to the light and you are good to go. You should then be able to remove the light from the Lightify app and add it back to your primary hub.
The other upside is the light may work better and be more responsive in your original app now as well. Hope this helps.
