New ISP and Router - Can’t find Hub
Hello All - I switched my ISP and got a new router. I’m trying to find my hub on the find my hub portal, with it plugged into the new router but can’t seem to find it. Is there something else I need to do to get it up and running on my new network? Appreciate the help!
Please disregard. I believe I’ve got it up and running. Apologies.
Your hub probably needs to request a new IP address from your new router.
Hiding in one of the vent holes on the bottom of your hub, there’s a little button.
Push it with a pen, paper clip, etc. That will cause the hub to reboot and request a DHCP-assigned IP address from your router.
You should be able to then browse to the hub at https://findmyhub.hubitat.com/
