This is driving me crazy, I just published on more version that just adds some log output to see what is going on. I am looking for lines like this:
Dining Room Fan Controller getting fan state: false determined by switch
or this when you turn it on:
Dining Room Fan Controller -> setting fan state to on with cmd: on and value: null
Would it be possible for someone to install that 0.2.11 version and get me this output? I would gladly take the whole boot log of homebridge as it shows me most things I would need
And just to make sure, you guys are not filtering any attributes or capabilities, like removing the switch attribute, right?
When I turn on the fan from Hubitat I get this in the log:
[5/28/2019, 7:49:35 PM] [Hubitat hhm:0.2.11] Change Event (Socket): (Living Room Fan:108 [LEVEL] is 50
[5/28/2019, 7:49:35 PM] [Hubitat hhm:0.2.11] Living Room Fan -> getting fan state: false determined by switch
I get no log output when turning off the fan from Hubitat
When turning on the fan from Homekit:
[5/28/2019, 7:52:57 PM] [Hubitat hhm:0.2.11] Living Room Fan -> setting fan state to on with cmd: on and value: null
[5/28/2019, 7:52:58 PM] [Hubitat hhm:0.2.11] Change Event (Socket): (Living Room Fan:108) [LEVEL] is 50
[5/28/2019, 7:52:58 PM] [Hubitat hhm:0.2.11] Living Room Fan -> getting fan state: false determined by switch
And off:
[5/28/2019, 7:53:51 PM] [Hubitat hhm:0.2.11] Living Room Fan -> setting fan state to on with cmd: off and value: null
Also, during the load there was this message:
[5/28/2019, 7:49:22 PM] [Hubitat hhm:0.2.11] Device Added (Cache) - Name Living Room Fan, ID 108
[5/28/2019, 7:49:22 PM] [Hubitat hhm:0.2.11] Living Room Fan -> getting fan state: false determined by switch
Thank you, I think I need to code myself a virtual driver that represents the behavior of this fan controller to really get to the bottom of this. I hate throwing versions around and picking in the dark
Question - when I update homebridge-makerapi I have been rebooting the entire RPi just to be safe. Is a reboot or restart of Homebridge still required?
I only did a quick test - but it appears to be working so far. I tested changing various states/speeds from both Hubitat and Homekit and both appear to be working correctly. I'll test more when the living room isn't full of annoyed family...
Thanks for all the hard work on this.
Fan off state seen in the logs now:
[5/28/2019, 8:30:25 PM] [Hubitat hhm:0.2.12] Change Event (Socket): (Living Room Fan:108) [SWITCH] is off
[5/28/2019, 8:30:25 PM] [Hubitat hhm:0.2.12] Living Room Fan -> getting fan state: false determined by switch
I've done it.. had multiple running... but right this minute, the critical elements are lost in the mists of time. Maybe by tomorrow those memories will have been restored from tape.
Create additional .homebridge folders.. aka .homebridge2 and .homebridge3
Then create all new config.json's with new "bridge" values. Every value unique.
then
sudo homebridge -U < path to each new config.json >
If that works, you're halfway and you can proceed with fleshing out the "platform" portion of each config.json
