We are both retired and building a new home with a floorplan designed to accommodate us as we age. I am intrigued and generally comfortable with technology but my wife is not (she just wants things to work easily). I have been doing a lot of research and developed the following gameplan.
We want as much of our home automation and security system to be wired and not reliant on WiFi to operate. I plan to wire Hubitate compatible devices wherever I can, e.g. switches, motion sensors, water sensors, temperature control, curtains/window treatments, smoke/CO detectors, garage door openers, video cameras, glass break sensors, doorlocks, irrigation system, and outdoor lighting. Initially, I will focus on the rules for security and settings for when we are away from home. Over time, I would start integrating the other devices and add settings for when we are home. My reasoning is that I want to see how we "live" in the new home given that the floor plan is very different from our current home. Also, I will be minimizing the number of brands so as to keep the integration simpler AND ensure operability as I add new rules/devices to the Hubitat network. To round out the networking plan, we will have WiFi throughout the house, CAT6/7 cable outlets in selected locations throughout the house, and the appropriate amount of router/switch equipment in an IT closet in the basement.
Here are my questions:
We like to travel and will be away from the home for weeks at a time. What is the best way to access the Hubitat network remotely to receive alerts and/or execute actions (e.g. turn on lights when motion is detected)?
I have not finalized my count but it looks like the number of devices will be approaching 200 altogether. What is the best way to ensure connectivity? Do I add additional Hubitat hubs? Can they be networked together as if there was only one hub?
We will likely use a security monitoring service. Can those devices also be connected to the Hubitat network, e.g. motion or door sensors? OR can alerts/signals from the security "board" be simultaneously forwarded to the Hubitat network? If I were to drop the monitoring service, how easy would it be to redirect those devices into the Hubitat network for self monitoring?
What brands for switches, doorlocks, motion detectors, window treatments, etc. do y'all recommend OR that work very well within the Hubitat network? While I am relatively comfortable with technology, I do not want to spend time trouble shooting device failures, etc. or spend time "experimenting".
If I understand it correctly, all switches can still operate in the manual mode for when we have visitors OR just want to turn on the lights regardless of the rule settings. In those instances, how do the rule settings operate? When does the system reset itself to the rules?
I was planning to setup two iPads (one for the first floor and the other for the finished basement) to access the Hubitat dashboard. I was also planning to use my desktop PC for setting up the rules and layout of the dashboard. Is that a reasonable approach for enabling other users, e.g. my wife, to access the network?
We currently have some Nest cameras and Amazon Alexa. I was not planning to integrate them into the Hubitat network initially. Eventually, I might want to integrate Alexa to give us some voice control, e.g. dimming lights OR check doors and windows. Is the integration of Alexa for these types of activities complicated? What devices are the easiest to integrate/control?
I'll probably have other questions as the responses come in but this should cover me for now. Thanks in advance for any advice/comments/suggestions.
