New devices that work! Yippie!
Ok, seriously, first for your viewing pleasure is the
Sonoff ZBMicro USB switch and zigbee Repeater.
It uses the zigbee/sonoff generic relays and switches.
Regrettably it does not have power monitoring to use for automations. It does send health status, presence status, as well as On/Off
Here is the link to it.
https://www.amazon.com/gp/aw/d/B0DDCHT457?psc=1&ref=ppx_pop_mob_b_asin_title
Now, I also found a 3 scene zigbee push button. It identifies as
  • manufacturer: _TZ3000_8rppvwda
  • model: TS0041
    The unit works well. It is using the driver for the Tuya s ene switch TS0041
The link to it is here
https://www.amazon.com/gp/aw/d/B0D637DFKW?psc=1&ref=ppx_pop_mob_b_asin_title
Now, I tried this one with success
Zigbee 24ghz mmWave Sensor
The device identifies as
manufacturer: _TZE200_3towulqdmodel: TS0601tuyaVersion: 2.1.1
And after installed, choose the second choice under device profile.
It is battery operated and can therefore be mounted anywhere.
Here is the link
https://www.amazon.com/gp/aw/d/B0D3M5Z2BW?psc=1&ref=ppx_pop_mob_b_asin_title
Next up is some tuya zigbee presence sensor. I have 4 now.
Tuya ZigBee MmWave Human Presence Sensor with Luminance
This device identifies as
  • manufacturer: _TZE204_qasjif9e
  • model: TS0601
And it is using the driver
Tuya Zigbee mmWave sensor
Device profile is for zy-m100
Here is the link.
https://www.amazon.com/gp/aw/d/B0DH1CW5HB?psc=1&ref=ppx_pop_mob_b_asin_title
Now I have found some temp/humidity sensors that work. Maxcio brand zigbee.
They identify as
  • manufacturer: _TZ3000_cx6atb9s
  • model: TS0201
Driver using is
Tuya temperature/humidity illuminance lcd display with clock
With the model group left at auto detect.
Here is the link, I bought 6.
https://www.amazon.com/gp/aw/d/B0CLL2FJPX?ref=ppx_pt2_mob_b_prod_image
I e other devices ordered and i will let you know what works and what does not.
Oh, and for anyone interssted, i have goten in touch with third reality about the zte05 temp humid zigbee temp humidity display and I will keep you posted.
Paul
