Hello, new to hubitat here. Setting up a BNIB C8, unable to discover the device and the led remains blue always. I have tried pressing the button for 7 seconds already, ethernet connection is confirmed working properly. Is there a way to attempt to connect this via wifi, or anything else I should try?
Blue means the device booted up, but the hub's main UI/platform aren't loading. You should be able to access the hub via the hub diagnostic tool at:
hubIPaddress:8081
You should be able to find your hub's IP address on your router.
Once you have access via the diagnostic tool there are options to troubleshoot your situation.
I have access to the router and the device is not obtaining an ip, I can see the mac in the switch config menu but no luck finding an ip. I tried the network reset process holding the button for at least 7 seconds, the unit never blinks or reboots and stays blue. Power cycling the unit didn't work either.
If you are having this issue out of the box, please be sure to create a warranty case by visiting the following page. You may be dealing with a hardware malfunction:
