Ive had a few devices like that. It has to wake up next event to report I believe. I would wait till tomorrow to look at it and see how it is. I would also switch to the generic z-wave lock driver instead (don't forget to click configure after clicking save) Seems to report better.
Thank you for the reply.
I had noticed before it needs an event to wake it up
I left it overnight and we have come and gone a few times using the lock which works fine. It just flashes red that the battery is low.
Is there a way to reset the lock without messing up all the Hubitat settings?
It has been working fine for years.
Just started 2 days ago
The lock locks & unlocks from the computer & iPhone
The lock reports back to the computer & iPhone that the lock is locked & unlocked
Are you absolutely sure the replacement batteries are good? There's also the case if you go from one shots to rechargeables, the rechargeables have lower voltage/ma/mw characteristics and that might cause issues if its expecting alkalines. Especially since the lock driver/app might not have been written to accept them and identify the differences.
Only use new alkaline batteries
These are Duracell dated 2031 from a newly opened the package.
Batteries, usually last almost a year
These ones were at 60% just a few weeks ago, then suddenly they were 40 and 20% in just a few days.
I have replaced them twice in the last two days to make sure they weren’t just a set of defective batteries
Thank you for the feedback
A brand new AA battery should read about 1.65 volts DC.
The fact that your lock indicates a low battery signal (red flash on keypad) suggests that either your batteries are not ok, or that something is wrong with the lock causing it drain batteries rapidly.
A multimeter would help you distinguish between those possibilities.
In terms of resetting the lock, do you have a C-5 hub or a C-7 hub?
