It appears to me that there is a bug for Custom Attribute as a Means to Turn Off. I will look into this, and update once I know what's going on.
Update: Found the bug with this, a typo. Fix will be in the 2.4.0 release.
A post was merged into an existing topic: Speculation on Platform 2.4.0
3 posts were split to a new topic: Speculation on Platform 2.4.0
Minor discrepancy crops up in RL under following conditions (clicking Update between steps):
Happy to show more comprehensive screenshots, but the gist is that the Button Controller's initial settings in the Grid get altered unexpectedly after Capture, meaning they go from this:
to this:
Namely, the button device's Off Btn column disappears, along with its preset values (both values default to 1), and its Off checkbox becomes unchecked.
All the other devices in the grid appear to have been captured appropriately, so am just calling out the Button instance here. Expected behavior would have been for the Button device to remain entirely unchanged (as there is nothing to "capture"?).
OK, I've figured out what is going on. It is true that using a capture device will reset the button number selections to 1. This shouldn't happen, so that will get fixed for the 2.4.0 release.
I can't reproduce the Off column selector going blank as you describe.
