I have 4 issues to report on IOS:
-- Drag down (spring to release) on a dashboard causes a refresh, which it should. Many apps do this. When the refresh has loaded it drops you back to the list of dashboards. Clicking the green checkmark to refresh does not do this behavior.
-- The scrolling in Dashboards on IOS is awful. Huge W.A.F. issue. As soon as you lift your finger off it stops scrolling. It should glide like every other IOS page and app. As a developer, no idea how you actually made it do this. I'm actually curious, because the normal "gliding" way is what a normal webpage does. This issue also happens on Dashboards in safari, so may be a "Dashboard" issue rather than "App issue".
-- The app randomly logs you out. Like after phone restarts, or app kills. Haven't been able to track down exactly what causes this.
-- HSM Monitor dashboard: Clicking buttons provides no acknowledgement you actually clicked a button. I think if you click a button the window should probably go away. This issue also happens on Dashboards in safari, so may be a "Dashboard" issue rather than "App issue".
Are u considering widgets for Android? I almost never use the app to turn things on or off because it is slow. Therefore I would like widgets to toggle HSM on or off for example!
Kasper
"edit" : the beta version is much faster than the regular one, but I would still like widgets!
What happened to the Push Notification List option in the iOS mobile beta app, I no longer see it so if I accidentally dismiss multiple notifications before reading them I have to search all over for the logs that were created when they were sent. Also is there any way to get the app to change to local immediately rather than after a 3 second countdown?
Notifications list was removed because it wasn't consistently adding all of the notifications. A new notifications screen will be added on the next release that will be more reliable and show a history of sent notifications even if the phone wasn't able to get it for any reason.
I posted the below comment on a similar post and thought it was appropriate here also.
I was having similar issue, it seemed that unless another application like my Arlo presence, or Life360 1st triggered a GPS update the Hubitat app wouldn't update unless I opened it 1st. Last week I enrolled in the Beta program, disconnected my Life360 to test the HE app. It immediately was the best I have ever experienced with any presence to date; almost 6 months with HE. HE app initiates and updates my presence and runs the rules I have created before ANY of the others even process. I really don't know exactly what the difference is but I am SO HAPPY!
Samsung Galaxy S9+ - Verizon
Android 9 August 1, 2019 build
HE App Beta 1.3 build:58
I'm getting just the opposite from above comments. My location with the app has been rock solid for the last couple months. And within probably 100 ft every time. No excessive battery drain either. Same with wife's phone. I have disabled Life360 as not needing it.
The iOS build keeps signing me out. I’ll notice that after a couple days my presence isn’t right. I open the app and it asks for credentials. Using version 61.
Not sure. I had to uninstall the beta and install the release to fix it. This, of course, broke everything that used my phone for presence or notification. Pain in the ass.
