Updated Android app. Got "no response from hub" on Dashboard page. I have 2 hubs in different locations. Switched to the second hub and now can't switch back to the first hub. App hanged on Fetching User Data. Everything was fine before the update.
Edit: App removal and reinstall didn't help. @chuck.schwer
Ok, I have android but I must be having a senior moment. Going to app in the play store or in the phone doesn't give me a way to refresh or check for an update.
Is this the Beta you are referring to? I don't do that but I guess I could. I missed the Beta build in the dang title!
@chuck.schwer
The main local hub dashboard page is working now in both local and cloud modes, but when I switch to the other remote hub the dashboard page shows this error:
{"error":true,"type":"AppException","message":"Not Found"}
The only difference between two hubs is that on the remote hub I still run under 2.1.3. Is it a problem?
By the way I see that in the new app version there is Advanced button which opens the hub upgrade function. I tried to upgrade the remote hub to 2.1.4, but nothing happened. Is it designed for local upgrade only?
@chuck.schwer Iβm using the IOS beta app and am unable to keep the geofence radius saved at its minimum level. It always resets to slightly larger than the minimum level, sometimes hours or days later.
This has been happening through several updates, any idea if there is a fix on the horizon?
Overall app improvements and new features are great. Loads faster, move through the app faster, dashboards load faster.
I do occasionally get a black screen when loading a dashboard, not on the same one each time. Go out and select again, it usually loads about 75% of the time, third time it almost always loads. Same thing happened on the previous version
