Networking Hubs
I have a home hub (c8 Pro) and an rv hub (c7). the home hub is atationary and the rv hub travels frequently. Each are tied to separate routers and are on different subnets. Should I be able to link our cell phones to each of the hubs for messages and presence sensing. ...and is there any recommendation for configuring. I can't seem to make "hub mesh" work.
From the hub mesh documentation...
"When two or more Hubitat Elevation hubs run on the same local network..."
AFAIK hub mesh requires that the two hubs are in the same subnet.
HubConnect is your answer.
It's in HPM, and there's instructions:
You should be able to use a site-to-site VPN, or a dedicated VPN gateway to make them both appear as if they are on a single local network.
Ask Gemini or your favorite AI bot how to do it.
THIS is the way
