Hey guys. The nest integration has been working great for me with my one camera. I have small request though. Is there anyway to change the resolution / size of the image url so that we can actually see the whole image on the device page? Or maybe add it as state variable so it can take advatage of the extra real estate on the screen?
Nest presence detection by the Protect devices is only used by the thermostat via 802.15.4 LR-WPAN
on a Zigbee chip. It is recorded in the nest cloud, but only uploaded once per day.
Announcements are not possible with the Nest Protect. Those messages you do hear are fixed in the firmware. However, if you want to make announcements in your home, you can use Google Assistant Relay to announce on Google Home devices via TTS. The announcements will be made via the default voice you have selected in the Google Assistant app. You can also control any device or trigger any routine setup in Google Assistant, with or without response. There is also some good progress in using Alexa devices for TTS and to trigger routines and you can expect to see official capabilities to do this via the Alexa Skill in the near future.
Hey everyone - I know it is beyond your control but has there been any word on increasing the # of users? Sadly came late to the Hubitat party and am left a little wanting in that regard..
One question - When I added Nest Integration via Tonesto to SmartThings I had to create a developer account with Google. Is it possible to use this for the integration on Hubitat?
If there were some way to provide the app with our Nest Dev ID and Token - it should just work right? As long as your account has enough user allocations whatever they are called -I have like 47 left or something.
Or are there additional things that need to happen?
Yes, NST-Manager eventually went the direction of requiring users to obtain and enter their own tokens. A minor hassle, but perhaps a reasonable workaround while stuck?
Since we are not sure when Google/Nest will open things up for HE and I really want Nest integration with HE right now I was hoping that maybe the HE crew could figure out a way to let us enter our own credentials at least in the interim. Maybe there are technical issues with this I dunno.
Can anyone confirm if this would allow the use of external geo-fencing to improve the home/away asist?
Currently I'm looking at either Nest or Tado thermostats for a 9-zone UFH with Air Source heat pump system with a very varied schedule across 2 people. Leaning towards the Tado for their software and ability to do accurate geo for varied schedule but vastly prefer the visual of Nest so wondered if this will correct that shortcoming?
Cameras:
I want to be able to take a photo/photo's captured by Hello or Nest Cams to the use for FR/ANPR to pass to a gate controller using Sighthound API - will this help with managing that process?
Would this expose the IQ elements already built in to be able to use their Facial Tech directly?
Unfortunately we are still waiting on Nest. Our original submission was kicked back to us with a couple changes required. We have since made those change but have not been able to submit due to this message:
