I can't figure it out how to config my NEO Coolcam motion detector
Does the driver of the sensor has a function to do a motion hardware resets at x seconds, or has the device a default motion hardware reset?
example: when the sensor is ON + continuous motion detection, after X time the sensor goes OFF and when there is still motion the sensor goes back ON.
With a xiaomi motion sensor this is in the driver:
After motion is detected, wait ___ second(s) until resetting to inactive state. Default = 61 seconds (Hardware resets at 60 seconds)
No, I think it is not supported in the hardware but I have made a workaround with a rule that solves my problem, but I guess it will not solve your problem...
Hello, this but not solve my problem, I want the sensor get inactive is didn't detect movement on x seconds, I don't know why didn't refresh this parameter, on smartthing works!, should be able to do this.
I am not a zwave expert at all, but does executeConfigure/pending not mean the configuration has to be pushed to the sensor by pushing the button in the sensor....
I have 2 Neo Coolcam PIR motion sensors. For the life of me, I cannot get either recognized. I tried resetting the device, tried an exclude then include Nothing happens. Press the button 3 times and get 5 blinks. Anyone have an idea?
Hi. I installed my NEO Coolcam motion detector a few months ago and the battery is stil at 100% too. Depending on how frequently the sensor is activated it can last a year or two, I've read. No idea if there is measurement flaw.
Battery monitoring is notoriously unreliable.
I’ve 2 x Neo Contact sensors which showed 100% for 13 months and are now showing 94%
If you’re concerned, you can find Apps like “Device Watchdog” to keep an eye on their state.
