My C8Pro recognized it immediately but gave it the 'Tuya Multi Sensor 4 in 1' driver, which of course does not work! Does anyone know of a driver that would work with this device, here is the fingerprint after being recognized
I tried using the generic driver on mine but it still doesn't register as a water sensor. Am I missing a step? Tried both normal and no temp with no change in options.
It may not be a bad idea to first switch it to plain "Device" (then Configure) and then use all of its available options to clear current states etc. Then switch to the desired final driver (and Configure again). That would ensure you have a completely clean slate for the desired driver.
As a general rule, battery-powered, sleepy Zigbee devices that were not automatically recognized by HE when first paired must be re-paired with the hub (without deleting the device), after the correct driver is identified and assigned.
