My Hub stops communicating and I can't log into the Hub via web or app. Devices also stop transmitting events and running schedules. Once i reboot the Hub everything works as normal but after a day or so it reverts back to no communications.
Do you have jumbo frames enabled anywhere in your LAN? Its been known to crash the hubs networking.
Also check logs. Past logs for errors, and apps and device stats for things that might be getting out of control.
Any user created Wifi integrations are especially suspect, those are what tends to jam things up if devices go offline and people do not have proper error handling in the code.
Also try diff power adapter. And if not on a ups try that.
