anybody have an example of some app code that does something like the following
thanks in advance
thanks in advance
so far gave up on this for now unless some can figure out (other thread) why the first call to the api is not returning the correct results even though i get a 200 back?
Instead for now I made some changes to run a .py script on a server and push new token to my local qnap web server and refresh token from that when needed. I did solve the sha256 and base64 encoding which in itself took me a half a day. ie.. Here is the code for that if it helps anyone else.
import java.security.MessageDigest
String.metaClass.encodeURL = {
java.net.URLEncoder.encode(delegate, "UTF-8")
def giveMeKey(int length)
String alphabet = (('A'..'N')+('P'..'Z')+('a'..'k')+('m'..'z')+('2'..'9')).join()
key = new Random().with {
(1..length).collect { alphabet[ nextInt( alphabet.length() ) ] }.join()
return key
public static String sha256(String base) {
try{
MessageDigest digest = MessageDigest.getInstance("SHA-256");
byte[] hash = digest.digest(base.getBytes("UTF-8"));
StringBuffer hexString = new StringBuffer();
for (int i = 0; i < hash.length; i++) {
String hex = Integer.toHexString(0xff & hash[i]);
if(hex.length() == 1) hexString.append('0');
hexString.append(hex);
return hexString.toString();
} catch(Exception ex){
throw new RuntimeException(ex);
log.debug "in Get token from login"
def verifier = giveMeKey(86).toString()
if (!state.internalState)
def internalState = UUID.randomUUID().toString()
state.internalState = internalState
log.info "Set internal state to $state.internalState"
else
log.info "Internal State = $state.internalState"
log.info " verifier = $verifier"
String challenge = sha256(verifier)
def b64Challenge = challenge.encodeAsBase64()
log.debug "before strip b4challenge = $b64Challenge"
int loc = b64Challenge.indexOf("=")
if (loc > 0)
log.debug "found loc = $loc stripping off ="
b64Challenge = b64Challenge.substring(0,loc-1)
