I'm having trouble updating some of my Leviton switches using the firmware updater provided by Leviton technical support, who unfortunately has not been terribly responsive to my requests for help. I want to try updating it using Simplicity Studio's Z-wave controller or, failing that, the Community App firmware updater. But both require this update file to be in *.hex format. I looked at the instructions for extracting the *.hex format from the executible and... frankly, it was all ancient Greek to me. So I thought I'd ask... does anyone have this file they can share with me, so that I can finally update my last few Leviton switches and experience the Hubitat awesomeness that everyone else is experiencing?
I stumbled across this today. Obviously use at your own risk but it's the .hex files for the Leviton switches:
Thanks. I ended up getting it to work with the Leviton firmware updater. But I'll keep this bookmarked... just in case.
Just a question here on that driver but isn't the OTA file supposed to be called an .ota file?
Sorry to hijack this thread, but I have a question on this topic. I am also trying to update several DZ15S and DZ6HD units through my hub using the hex files linked above.
My hub reports that the firmware was updated successfully. However, when I go through the process again with the same device, expecting to see the new firmware number now reflected, it's reporting the same version as before. I have power cycled the devices also and no change.
Is this normal behavior?
Thanks in advance!
I don't think that's normal. For me, the problem was that the firmware updater would not find the devices needing the update. I had to rerun it 20-30 times before it finally found those devices, and once it did, they registered as having the updated firmware.
