I have two floor lamps that I just changed from regular smart bulbs to Third Reality RGB bulbs. I also have a Home Pod, and a scene set up in Home Kit called evening. It turns off certain lights in the house, and would dim the floor lamps. With the RGB bulbs, I have them change to a certain color.
The Third Reality bulbs are not compatible with Home Kt, so my work around was to add a virtual switch called Evening. When it's on, the bulbs change to evening settings. When it turn off, they switch back to daytime, which is color temp of 2700 and 100% brightness. So far, that works just fine. I tell Siri to set the scene to evening, and Home Kit turns that switch on, and the bulbs change color and dim.
Here's my first world problem. I'd like to have some way to have the bulbs switch back to daytime settings just after sunrise. In my sleep deprived state while setting this up last night, I just set up a simple rule to turn the switch off at that time. And got a surprise this morning, while still in bed, when the lights turned on, because that's what they're told to do with the switch is turned off.
The problem is, if I'm up at that time, I want the bulbs to switch over. But usually I'm not up. And, when I do some workaround like this, usually in about six months I'll have guests over or something, and things start turning on and off on their own, because, well, normally that works just fine.
So, the question is, is there any other way to have HomeKit be able to change the bulbs to evening mode when I change the scene, but tomorrow when I turn the lights on, but I'm not ready for evening mode, to have them already set back to daytime settings?
EDIT: To simplify the question, is there any way to have Hubitat change the settings on a bulb from RGB to color temp without turning the bulb on?
