Need help to configure hubitat hub for a WT00Z5-1/WS15z-1 configuration
Hi @support staff,
I'm using a C7 hub Platform version 2.3.9.177 and I want to configure a set of GoControl/2GIG WT00Z5-1/WS15z-1 switches has a three way setup.
Can you help me for device type drivers for each module and how to setup the miroir/follow option?
Modules has been included in hubitat for now as:
WT00Z5-1 : Generic Z-wave smart switch (Slave smart switch)
WS15z-1 : Generic Z-wave plus switch (main switch with load)
I tried using the mirror app, but the slave physical press don't change the status of the main switch, the main switch works ok
Sorry, I'm new with Hubitat, I'm actually swithcing from Vera to C7
Thank you
Generic z-wave switch driver should be fine.
for both?
generic z-wave plus driver.,.. yes for both. Also note when changing drivers on a device page, after you click save, click the configure button.
I am not a Z-wave expert, but according to Zwave central scene switch and dimmer fingerprints you should look at the bottom of the Device details page, and see if it has the 0x5B cluster. If it does, that driver listed in the linked thread (Zwave central scene) should be the correct one. Be sure to hit Configure and save after changing drivers.
If it does not have that cluster, or still doesn't work, then maybe post the inclusters your device has and someone can figure out what driver should work.
