I have a hubitat as well as home assistant and node red.
Last time I just connected the dimmer to hubitat as zigbee and used rule machine, but it was EXTREMELY buggy. Is there a better way? Maybe use the hubitat h.a to node red? @aaiyar
Thank you
Thank you
Make sure this isn't a zigbee mesh issue ....
Rule machine is buggy as well. Iād rather not use it. Does the dimmer go into the h.e, h.a intergration? Iād much rather use node red
