Need Generic Zigbee Lock Driver
Valid values for a lock capability's locked attribute are locked, unlocked and unknown, event values are what trigger events within applications, there isn't any "locked by keypad" that's part of the current event schema for locks, it's added to the description text which is part of an event, but description text is not a constrained attribute, meaning it's optional and can be anything or nothing at all and therefore we don't attempt to parse it in applications.
Well, it would be nice if you could include that info on a "currentEventValue" I can't imagine it would be much to do. It took me adding three lines of code with SmartThings.
Use an app. I modified something else for my schlage and have since upgraded to yale zigbee with it.
we attempt to stick to defined attributes and capabilities for our internal apps and drivers.
Ideally there should be another attribute that's part of locks and or lock codes that allows publishing the means via which the door was locked or unlocked, right now there isn't such a thing...
Not quite sure I understand that. Obviously there is some attribute to trigger that log.info to "Locked by Keypad". It's not like it came from thin air and only gets triggered when the lock was locked with the keypad.
I believe mike is saying that this is sent by the lock, but maybe there isn’t currently a way to use this info in Hubitat.
Applications do not use, nor should they use the description text attribute, they use the attribute values shown in the device current states which is the same data shown in the value column of device events.
Thanks for this. Easy edit taking "[physical]" off and that was it.
@abuttino did you get further with this? I took a copy of the driver posted earlier in this thread and I was able to modify it to pass the details in the event data. In webCoRE I am able to access it with $args and with a bit of parsing I know how (auto, command, key, keypad, thumbturn) along with who (name & code) with my lock/unlock events. I am going to take a stab at getting the error conditions for bad PIN and invalid schedule. If I am lucky I will be able to pass it up as an "unknown" event along with the data. I coded it but won't be able to test that part until tomorrow as the wife is asleep and the lock is loud. lol
I ended up altering the App that someone posted in this thread. If you need, I can probably put the code on Github.
