We moved into our current home about three years ago, and although I removed most of the automation stuff from the previous house, I treated the new one as a clean slate. The new house had 23 6” can lights with dumb bulbs and trim rings that either needed to be replaced or painted. I replaced all 23 with Hue retrofit bulbs. I also replaced virtually every switch in the house (40+) with Inovelli Blues.
To say it was a tough nut to swallow would be a huge understatement, but I did a good amount of research before pulling the trigger and this was the only path that gave me what I wanted. I guess you could call it my prime directive, but to the largest extent possible I want everything in my house to work as expected even if the controller goes down. If there’s a switch on the wall that controls lights, it has to work 100% of the time. No ifs, ands or buts. Automations are a convenience, not a necessity.
Of course, any automation-capable dimmer switch along with dumb bulbs will satisfy that requirement, but I wanted to control color temperature and, in a few cases, the actual color of the bulbs as well. That meant using smart bulbs along with switches that could directly control the bulbs. Wifi bulbs were out of the question, as they’re a huge violator of the prime directive. Both zwave and zigbee can operate independently of a hub (once they’re configured), but zwave smart bulbs are almost non-existent. When it comes to zigbee, Hue has a reputation for being the most reliable and Inovelli demonstrated that their blue switches could directly control Hue lights, so it really was the only path that gave me what I wanted.
The pain of spending that much money has passed, and I don’t regret the decision. If I get hit by a bus tomorrow, every switch in my house will continue to work as expected. I’ve since added 9 additional Hue downlights to my garage and another 3 during a small bathroom remodel.
As someone else has mentioned, you cannot use the Hue hub because the switches and bulbs must be on the same zigbee network for direct association to be possible, and you can’t pair Inovelli Blues to a Hue hub, unfortunately.
However, I also have 12 Hue A19 bulbs, and I recently moved them from Hubitat to a Hue hub to take some of the load off HE’s zigbee network. Being table and floor lamps, they’re not a permanent part of the house and not controlled by wall switches (I have Hue remotes for those). If they stop working because I get hit by a bus and the system goes down, the bulbs can always be replaced with dumb bulbs without my wife having to call in an electrician or a home automation expert.
