i gope this is easy what im trying to do, but i cant seem to get it to work. if i do it without the motion sensors it will turn on/off regardless if anyone is in the room or not.
it wont turn the lamp off
ok i think i may have figured it... ELSE after ON:Front Room Lamp & before Wait for conditions.....
id this right?
I would suggest you can simplify this a bit by using the built in app zone motion controllers it will make a virtual device out of those individual motion sensors. With this the "OR" and "AND" becomes a bit more simple. Also you can pivot your "If" to be about the change in motion vs. luminance and use luminance as conditions in actions.
I
