Nash: a standalone LOCAL notepad as a single HTML file
https://keepworking.github.io/nash/
I copied the source to a local html file. Then I removed some icon urls and replaced the broken ones in the format bar with text (link, image, download). I also searched the code for http & image links, finding only the above link in the footer.
I put the modified template in my Downloads folder and bookmarked it in FF. When you save, it writes a copy to the downloads folder and does not overwrite. Works!
Just last week I was searching for "modify local text file in browser."
I happened across Nash on Hacker News today.
Thanks for posting this. I remember seeing this on HN! This was the HN discussion:
A good read, thanks.
Because Nash writes an html file I can use tampermonkey to manipulate content locally. Mostly, I use Nash to write notes while browsing and stash them in a NashNotes directory.
(rocking side-to-side trying to justify Joplin... Mobile integration and markdown.... phew.... inhale.... :wink: )
Nice find,,,, neat, simple solution.
When copy-pasting from web to Nash, it generally does a very good job of keeping the formatting. I find this particularly helpful when moving reports to local.
