After updating my C5 today I’ve had a few problems now.
Sunrise trigger not working.
Dashboard sometimes does not update without refreshing. When you turn off / on a switch it sometimes get stuck on “sending” even when the devices works as expected. After a refresh of the dashboard the correct status is shown.
I have not updated yet, but I have always had trouble with dashboards not updating- especially on a desktop browser- unless I refresh. Are you sure this is new?
Yep worked perfectly on the app before the upgrade. I was actually playing around with the dashboard a few nights ago and all worked fine, today after the upgrade seems to be buggy.
So I reverted back to the previous version, hitting the refresh button a few times I can still see the ON/OFF flip flopping however it works perfectly from the dashboard. I must have clicked on and off 10/15 times from the dashboard and it worked perfectly.
So something definitely changed In the new version ?
Switching on and off at the dashboard after about 2/3 attempts it will get stuck at sending. Refreshing the dashboard will show either on or off but normally not the true status.
If I go into the devices section and click on / off it will mostly skip on either the second or 3rd attempt.
Hitting refresh while in the device section and the device is off, will switch between on / off. Randomly in the status section. This does not trigger the device on and off in reality so it appears it’s only a status check. I had not seen this in the previous firmware however it does appear to be the same.
After reverting the firmware all has returned to normal. I can switch on and off multiple times with any problems. I also noticed when it would get stuck on a sending status the dashboard would also fail to update on other devices.
I just retested on the latest hubitat release on the C7 hub and I can confirm it’s still a problem.
When you get the “Sending” status from the dashboard of you change the brightness or select refresh from the device it appears to clear the problem.
Also if you hit refresh a few times on the nano leaf from the device manager it switches from ON/Off randomly. Like before it does not change physically.
Anyone else seeing this problem. ? It’s really easy to reproduce.
