MyQ Lite app device error
I am trying to add my two garage doors using MyQ Lite. I downloaded it with the Hubitat Package Manager and was able to add the two doors in my MyQ account. But there are errors in the device logs and nothing seems to be working. The error is:
groovy.lang.MissingMethodException: No signature of method: user_driver_brbeaird_MyQ_Garage_Door_Opener_NoSensor_738.updateMyQDeviceId() is applicable for argument types: (java.lang.String, java.lang.String) values: [CG2863539C98, 89535d16-0993-45c4-adc2-595c4b0ebab6]
Possible solutions: updateMyQDeviceId(java.lang.Object), getMyQDeviceId() on line 602 (method updateMyQDeviceId)
Can this issue be resolved?
You need Hubitat-compatible door position sensors to use this integration.
I thought that you could use the NoSensor version if you don't have door sensors. Did I misunderstand what the NoSensor version was for?
Yes. If you want it to work reliably, get a door sensor paired to Hubitat. I use an Aeotec Door/window Sensor 7, and MyQ Lite works fine. Others have success with a tilt sensor.
How did you implement the Sensor version of MyQ ? thanks
If I remember correctly, you need to re-install the app and choose the sensor option.
